(Help please) Possible morph overwriting Genesis 8 Aiko 8 and Nyao
shadowhawk1shadowhawk1 Posts: 2,211
edited February 2020 in The Commons
Hey all. I just started to tinker with Genesis 8 and tried to load Nyao and the morph came out all scrunched up. I looked and I am not finding any stray morphs I might have had loaded but when I load the Nayo body it loads with Stiletto nails loaded but if I go in and laod the body manually it doesn't load. When I try to load Nyao's face it acts as if I am taking the morph past 100% and there is a large crease down the center of the nose. Can I get someone to load a base G8 a base A8 and Nyao so I can compare them agaisnt what I have loading please?
I am at work right now so I can't load an image to show what is loading for me but I can do so after work.
Post edited by shadowhawk1 on
  • TheKDTheKD Posts: 2,711
    Just using the defult settings on the camera, or do you need a specific camera setting to compare?
  • shadowhawk1shadowhawk1 Posts: 2,211
    Default camera view will work I am just wanting something I can use to compare thier likeness's
    We don't appear to have nyao, but I can do g8 and a8 at least.
    790 x 637 - 178K
    Post edited by TheKD on
    Thank you for posting the base figures. They both appear to look the same as mine so it must be the Nyao morph. Can someone pleasse post an image of their version of the Nyao base morph please?
  • benniewoodellbenniewoodell Posts: 2,001
    I tried to match the camera angle as best I could from the other photos posted here.
    Also in the shaping tab, Aiko head is at 60% and Nyao is at 100%, don't know if that helps at all.
    Glad I checked the forum before going to bed, hopefully this helps!
    969 x 658 - 142K
    Post edited by benniewoodell on
  • MickyBeMickyBe Posts: 365
    Here is a comparison between G8/A8 & Nyao in my DAZ Studio...
    I hope it will help you.
    760 x 898 - 176K
    1094 x 596 - 118K
    That is what mine loads at but it looks no where near that. I will have to post what I am getting later today when I get off work. Meant to do it last night but RL got in the way. Thank you for posting the image for me to check agaisnt my version.
    Thanks for the close up, looking at your characters none of mine look anything like that. Mine G8 and A8 seem to have some kind of smirk on their faces.
    OK I redownloaded and reinstalled A8 and Nyao and that seemed to have fixed part of the problem but it still looks like I have a smile or smirk morph dialed in somewhere but I can't find it anywhere and it is not showing up in the currently used parameters. Looking at G8 it looks like there is a figure moprh loading in ontop of everything. Anyone got any ideas?
    1538 x 951 - 1M
    618 x 618 - 396K
    477 x 477 - 195K
  • LeanaLeana Posts: 13,519
    Do you have "show hidden parameters" enabled in the parameters tab? If it loads automatically then it may not be shown in "currently used" by default.
    That was one of the first things I thought of to try. I looked through all the head morphs and facial expressions and nothing is dialed in that I could find.
  • TykeyStudiosTykeyStudios Posts: 892
    Curious, when you checked 'Currently Used' did you look in the Parameters Tab and the Shaping Tab? I've had morph issues like you, but the issue showed up under Currently Used in the Shaping Tab but not in the Parameters Tab and vice versa.
    Post edited by TykeyStudios on
    Hi glenn, I checked currently used and all in the parameters tab, I do not have the shaping tab since it has the same info as the parameters tab. I have a feeling I might have to remove all of the morphs with the exception of the base G8 and start slowly putting them back until I find the morph that is causing the issue and delete it.
  • You can add the Alondra character to the list. It may be a coincidence, maybe not but DeviousDolls made this and the Nyao character. Other characters that "require" aiko 8, like Giada or Yuka had the similar problems. I think Yuka didn't have it this bad but it was visible
  • I don't know if anybody is going to read this but the way I fixed this problem, more or less, was to remove the LY Rory Head morph and also reduced the Aiko head paramteres to 31%, still not perfect but waaay better then before
