Turning off all light
When I started with DAZ back in the middle of 2019 - I made a scene that was lit entirely with "Ghost Lights" and Emissive Shaders. When I had this problem back then the solution was simple: put in a spotlight and point it away from the scene and it worked fine.
Now I have opposite problem - i'm trying to position and work with a spotlight, but DS's work light(s) will no longer turn off. I know this is a topic that has been brought up before and I've read several threads and tried several solutions to no avail, so i'm unfortunately bringing it up again.
My example is a very simple scene:
- 3 Primatives, 1 Spotlight, 1 Camera
- Camera's headlamp is set to off. I don't think it's the headlamp though, because the light clearly comes from the right side of the frame.
- Render Settings: Auto Headlamp  is set to never.
Can anyone help?
1225 x 773 - 235K
  • MarcCCTxMarcCCTx Posts: 947
    Try looking at the Environment tab of the Render Settings, you may be getting light from there.
  • Solved! Thank you!
    In the Environment tab of the Render Settings, set Environment Mode to Scene Only (was Dome and Scene) that elminated what must of been a Dome Light of some kind!
    Thanks for your help!
