How to set hotkey for Local & World Coordinates under Tool Settings for Trans/Rotate tool?
If you have the Rotate or Translation Tool selected, you can change between local & world coordinates in the Tool Settings, but I'd like to be able to set a hotkey for local coordinates and a separate hotkey for world coordinates. How would I achieve this? I looked through the F3 menu, but couldn't find them.
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/viewtools/view_tool_set_coordinate_space/start
Hmm, are you saying that I can tie the script to a hotkey?
So, I press a hotkey, it runs the script which changes the coordinate from local to world under tool settings?
Yes, any script can be made into a custom action (most easily by right-click on its thumbnail in the content pane) and then assigned a shortcut in Window>Workspace>Customise.
Thanks, this worked out great.
I modified the script and turned it into a toggle, hope someone finds this useful, you only need one hotkey, and it toggles between Local & World:
It is possible to modify this script to switch between World Coordinates and Screen Coortdinates?
Thank you.
The sample script shows the codes to use for each coordinate system http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/viewtools/view_tool_set_coordinate_space/start
Thanks Richard, but the script only mentions the code "If the apppliation version is older than 4.11.0.52".
Finally I discovered that it is enough to replace "DzUniversalTool.LocalSpace" with "DzUniversalTool.CameraSpace" in the script uploaded by Fortale.
Thanks again.
