Help Exporting G8 to hexagon ..she's huge?
Kharma
Would anyone be able to tell me what settings I should use tto export G8 to Hexagon? I have used the DS setting at 100% and she is huge coming into hexagon. when I load her into DS I remove eyelashes and set her to base then on the export I have tried both the Hex and DS export options which both seem to be the same. Also, should I be unchecking write groups and write materil objects so that in Hex she is one object, or how in Hexagon do I make all her parts into one object and make her a different color so I can see what I am modelling on her?
I have several tutorials for using Hex but none of them seem to start at the Export your person from DS using these settings ...
Edit: So I ended up using the export options for Silo. but not sure if that's the correct way to do it?
