Importing Hexagon objects into Daz Studio
This discussion was created from comments split from: I can't see any fur in render.
I dont know is this a good place but i have a question. I made a object in Hexagon and color that objects. But when i transfer that object in Daz 3d it turns white. He dos not hold any color. How cani fix that?
Solit into its own thread since it wasn't related to the original.
If it was just flat colour you can reapply that in the Editor tab of the Surfaces pane - with the model selected in the scene, you can select its surface(s) on the elft of the Surfaces pane Editor tab and then adjust the base colour via the picker on the right. If you have painted textures, assuming the mdel was UV mapped, you can apply those through the same place - click the icon to the left of the colour conrol and from the menu select Browse.., then find the exported image and select it. repeat fro other surfaces or properties as needed.
