Veins and other HD Details Not Showing Up
FauvistFauvist Posts: 2,290
Some of the characters come with sliders for veins, and I have Add Some Veins.  I'm using Genesis 8 Male.  I set the veins or other details, like scars, at 100%.  I do a iRay render. And the veins and other stuff don't show up at all.  What am I doing wrong?  Do I have to set something?
Thanks!
    Turn up the mesh resolution/subdivision. these types of things show better with a denser mesh.
  • FauvistFauvist Posts: 2,290
    Is that the sub D Displacement Level in the Surfaces tab?
  • Under the figure in the parameters tab, go to the general category and there are two options: SubDivision Level (which will turn the mesh high res but most computers with struggle moving things around), or change Render SubD Level (Minimum) (which will do it only at the time of rendering.).
  • XpiderManXpiderMan Posts: 426
    Wow, thanks for those tips, FSMCDesign and GhostofMacbeth! I always thought it had to do with lighting, where some show more details than others.
    NP. lighting does play a part in showing the details depanding on the angle of light
