loading hair resulted in gray blocks ? help
AristocAristoc Posts: 254
edited March 2014 in New Users
i got some hair called Ciara from rendo.
i extracted and moved everything over like I have other times.
but i got an error saying that one of the files was missing and then i clicked OK and this resulted in a gray square block on her head.
what is this and can this be corrected?
362 x 206 - 18K
Post edited by Aristoc on
  • fixmypcmikefixmypcmike Posts: 19,742
    Make sure that the Data folder from the product is directly underneath your DS content folder (e.g. "My Library\Data", not "My Library\Content\Data").
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,845
    open the zip and inspect it first to see if it has all the files needed
    you get a grey block when missing a file usually
    is it just a texture or missing a texture?
    or maybe misnamed or in wrong place?
  • AristocAristoc Posts: 254
    edited March 2014
    I checked and the file is there in the zip.
    1372 x 631 - 107K
    Hello Guys and Gals .
    This time I moved the 'data' folder that was inside the zip over into the same folder as 'data' in my daz 3d library as suggested above.
    And....it worked...hair loads....I wonder what i missed the firs time?
    thanks so much for helping out this late. awesome!!!
    have a great weekend to you both
    Do a search in your OS file manager...you probably 'nested' the data folder and quite likely now have a duplicate hiding somewhere on your hard drive.
    i can definitely see the duplicates on my content folder. will have to organize everything soon. thank you.
