are you rendering from the active viewport or from a camera?
AristocAristoc Posts: 254
I am rendering right from my active viewport. No need to set up a camera since it takes extra time.
  • SimonJMSimonJM Posts: 6,108
    But with a camera (which takes all of 2 seconds to create) you get a range of options and control not available via the viewport. It is really worth taking the time to have a look and play.
  • fixmypcmikefixmypcmike Posts: 19,742
    Also cameras get saved with the scene, perspective view does not.
  • Miss BMiss B Posts: 3,071
    edited March 2014
    What they both said. ~points up~
    I actually have a Startup Scene that has 2 cameras in it, one for rendering (which I lock in place once I have the view I want to render), and the default camera, which I often use for getting up close when I'm posing hands and/or fingers, especially when the character is holding a prop.
    Post edited by Miss B on
    I only use perspective to fly around the scene and leave my camera(s) static at where I want the actual render to be. I'll do spot renders out of it sometimes, or quickie renders for the forum to help answer a question, but that's about it.
  • JaderailJaderail Posts: 0
    edited March 2014
    I use Active Viewport to set up scenes, then switch to a render camera with Aspect ratio on. Then I can tell which props will effect my final render (test render from Active for shadows for example) and which ones I can remove to save on Ram and file size. But not to render with.
    Post edited by Jaderail on
  • alexhcowleyalexhcowley Posts: 2,411
    This feature of cameras has saved me no end of hassle.
    And this tip is going to save me a lot more.
    Cheers,
    Alex.
