Victoria 4 for Genesis 2 Female
Raitan2008Raitan2008 Posts: 27
I bought this, but it comes with virtually no instructions...I am trying to apply old V4 textures using the V4 uv but nothing works...does anyone know the step by step for this product? It says all texutres must have duf format, but how do I tell that?
  • Raitan2008Raitan2008 Posts: 27
    It also says I am to say the textures in duf format...I just did a search for duf files in ALL my poser files and I got zero...how do I convert textures to duf format?
  • MelanieLMelanieL Posts: 7,817
    edited March 2014
    Two ways to do this. (Well, maybe more, but 2 that I know about)
    Method 1: If you have the V4 figure (i.e. Victoria 4.2) load her, apply the texture set you have, then save as a materials preset - this will create a .duf file which you can load onto G2F. (It should get saved in the "Presets" folder of your content library - you can change the location as you save if you have somewhere else you want to put it - if you are converting a lot of textures you may want to setup subfolders so you can find things easily in future)
    Method 2: Load Genesis (i.e. Genesis 1) and apply the V4 texture to that. Save as a materials preset as above.
    The diference is that the original V4 figure has an extra eye surface material zone, as does G2F, so the .duf created from original V4 will be "complete" i.e. include this material zone. Genesis (1) lacked this so the .duf saved will not include this. I think this zone is largely used for reflections, so you may not notice/care if it is not saved.
    Post edited by MelanieL on
  • AristocAristoc Posts: 254
    Im not sure but Ithink this might help make things easier?
    http://www.daz3d.com/v4-skins-auto-converter-for-genesis-2-female-s
  • Scott LivingstonScott Livingston Posts: 4,351
    edited March 2014
    There are some instructions and more information in the official thread. But basically it's what MelanieL said. :)
    Post edited by Scott Livingston on
    so could you tell me how I actually SAVE the file as a material preset...what options do I click?
  • fixmypcmikefixmypcmike Posts: 19,710
    File > Save As > Material Preset
    thanks...found a tutorial also in the freebie section too...
