How do you see an expression before applying it?
Genesis 8 comes with default facial expressions, example: Bereft HD, Angry HD, etc. How do I preview these expressions before applying them? There should be a picture in the Pose Control list, but there isn't.
There's probably a button I can press that toggles the pictures that go along with each expression yes?
I don't have preview thumbnails; I don't think there are any for those parameters.
Note that these are HD morphs (there are a few others here and there in the G8 anatomy) so if you want to see the morphs in the Viewport, you'll need to adjust the SubD settings on the Genesis figure (Parameters tab>General>Mesh Resolution). I usually set both SubDivision Level and Render SubD Level at 3, that should let you see all but the most insanely high-detailed morphs.
Unfortunately not all expressions come with previews. If there are menu items in your product library they should be visible. (and those really should be larger, IMHO, but that's another thread.)
