Headshop 12 for G8 does not install
efron_24efron_24 Posts: 478
[Headshop 12 for G8 does not install] there is no morpher zip file.. just a folder
  • Cris PalominoCris Palomino Posts: 12,959
    You don't use DIM to install?
  • efron_24efron_24 Posts: 478
    there is no option for DIM when you buy this
    it comes with a zip and a folder that should be a zip
  • Richard HaseltineRichard Haseltine Posts: 111,325
    edited January 2020
    It's a plug-in so I would expect it to have a DIM installer, and the file list on the read me page is set up for DIM. How big is the zip? Does the folder include the .exe file for (I assume) installing the plug-in?
    edited January 2020
    thank you because all goes well untill that morpher .. zip.. there is none
    a good working DIM would be perfect in this case
    Post edited by efron_24 on
    1129 x 368 - 99K
  • What do you get if you download? Sorry, I keep having second thoughts about this and want to have everything clear before sending n an email.
    edited January 2020
    it opens 2 folders from daz3d.com
    The upper one HS12forG8, has a ZIP file
    The Morpers file does NOT...
    As my daz studio is in the F file I have open everything in F:DAZ3D anyway
    but as that did not work I also put it in c:/programfiles/daz3d folder
    both has no effect
    when i open Daz studio 4.12 64 bit   there is no headshop in the edit file.
    the ZIP from HS12forG8 works ok.. it's 3 folders (as seen in the read me file and video) are in the right place
    1366 x 777 - 236K
  • videoninja719videoninja719 Posts: 344
    edited January 2020
    sorry just asking thinking of getting this. whats the different of version 11 vs this 12? any upgrade price for 11 user?
    Post edited by videoninja719 on
    edited January 2020
    both has no effect
    have you watched the install tutorial?
    yes. It says there should be two zips.. but there is one
  • let me know the updates. i want to upgrade my hs 11 to 12
    I am sure a solution will be found and i let you know
  • OK, thank you for the extra details - I can now send an email, though I suspect it won't be fixed before Monday.
    no hurry..
  • Please email me and we can set up a skype call over the weekend to sort this out for you.
    Skype name is lasloves, located in California near San Francisco.
  • LindseyLindsey Posts: 2,017
    Here's the upgrade product from HS11 to HS12.  It was released on 12/2/2019.
    https://www.daz3d.com/headshop-12-with-lovechild-win--upgrade-from-hs11
    Thank you .. but sorry I have no skype ... is there an other way ?
  • Hello,
    I purchased the headShop today. Did everything the video explained. I open DAZ and in the edit menu there is no headShop plugin.
    What do I do?
    I installed the 2 folderds and double checked that all reqired files are in place.
  • info_b3470fa520info_b3470fa520 Posts: 901
    edited March 2021
    Had successful skype with Ziv. As expected, his Studio was installed in a non-default way and when he installed HeadShop, he used default destination instead of installing to the actual folder.
    How do you find where your DAZ Studio is actually installed?
    1. If you have a shortcut, right-click and ask for "Find Location".
    2. If you are in DAZ Studio, go to Help/About Installed plugins" and click on any plugin. You can read the location where the DAZ 3D/DAZStudio4 folder is installed.
    When installing HeadShop, you must browse to this location. Make your "DAZ 3D" folder the destination!
    Post edited by info_b3470fa520 on
