GTX 1650 not being used in rendering. - SOLVED
scyhocescyhoce Posts: 69
edited January 2020 in New Users
Hello I have GTX 1650 6GB, and I've been trying for ages to make it render my stuff, but I couldn't. The cpu is the one doing the job. I know this thread made several times but non of those helped me. Most people say there isn't enough space in the GPU to handle my scene, even though it's a just a character G8 that has nothing on her. So I really doubt it's that. I tried ticking GPU alone in render settings and leaving out CPU, but when I hit render it doesn't do anything. I even lowered the iterations down to 300 but with no use. I tried turning off OptiX acceleration thing, that didn't work either. The GPU does a good job in other softwares like in redshift and prorender in cinema4D. so I don't know what's wrong. Could it be that I installed Daz on an SSD? it would be strange because C4D is also in there and it has no problems. I read Daz manual but I couldn't link what's in there with my problem.
Post edited by scyhoce on
  • Can you render a cube or sphere primitive (Create>New Primitive)?
  • scyhocescyhoce Posts: 69
    edited January 2020
    No, I tried disabling Optix and doing everything I mentioned above
  • You didn't list trying a scene with just a promitive, though, which would be a test of memory. Which driver version are you using?
    417.88
    I would hugly appreciate any help on this. I'm getting frustrated.
  • Richard HaseltineRichard Haseltine Posts: 108,056
    edited January 2020
    So you have tried a scene with just a primitive? What does the log file say after trying to render (Help>Troubleshooting>View Log File; the relevant section will be at the end)?
  • Sorry, I was losing track of versions. If you are using DS 4.12 then the minimum driver version is 430.86, so 417.88 will fail.
    I'm sorry too, I went to sleep. Also I'm sorry for not being able to make myself clear, English is not my first langauge. I meant That I did indeed try rendering a primitive but that did not work as well.
    So do you mean this could be it? that would be amazing, Do you recommend downgrading Daz3d itself or the driver?
  • Unless you have a back up of an older isntaller for DS then you would need to update the drver - 430.86 was pretty good, although I can't use it on my new PC; the version I currently have, 441.66, also seems to work well.
    Thanks! I finally got the gpu to work now. I downgraded to 430.86 and it seems it fixed my problem. Much appreciated!
  • Me too have the same issue. I have  NVIDIA GeForce GTX 1650 with 4 GB memory.
    I have installed Geforce Game ready driver 446.14, the latest one.
    Here are the details
    Driver version: 26.21.14.4614
    Driver date: 15-05-2020
    DirectX version: 12 (FL 12.1)
    Physical location: PCI bus 1, device 0, function 0
    Dedicated GPU memory 1.9/4.0 GB
    Shared GPU memory 0.1/7.9 GB
    GPU Memory 2.0/11.9 GB
    Any help?
    Are you sure it is not being used? Though 4GB of memory, if that's what Iray sees, is not very much.
