draw text in opengl viewport?
I need to draw text labels on elements in the opengl viewport in Daz4.6. I'm overriding the DzNode draw() method and am able to successfully make other opengl calls, but I am not finding a simple way to draw text. All the examples that google turns up involve GLUT calls that don't appear to be available in the Daz SDK environment.
What is the easiest way to do this?
Thanks
Dz3DViewport inherits QGLWidget. QGLWidget provides renderText().
-Rob
Thanks Rob, I gave that a try but with mixed success -- it seems to be invoking 2D draw calls on a canvas on top of the 3dViewport.
Which calls does DazStudio itself use to draw text in the viewport? For instance, using the universal manipulator tool, if you rotate/translate/scale an object in a scene it draws text next to the manipulator to show how far you've moved/rotated/scaled the object. My sense is that this isn't done using teh QGLWidget::renderText() method.
Thanks
DAZ Studio, the Universal tool, the tools that derive from it, use exactly this method..
-Rob
Ok thanks, I'll keep tinkering with it. I read in the QGLWidget docs that this method invokes non-GL native paint calls :
I tried wrappering my renderText call as described above, but to no avail. Any chance someone could provide a simple example of this that works in DazStudio?
Thanks
I'm still trying to find a way to render text to the viewport -- I'm calling the QGLWidget::renderText() method as described above, but I am getting a linker error during the MOC compile. I've included QGLWidget, qgl.h, which declares the renderText() method, but for some reason MOC is not seeing it? Any suggestions on how to get this to build?
Error 1 error LNK2019: unresolved external symbol "__declspec(dllimport) public: void __cdecl QGLWidget::renderText(int,int,class QString const &,class QFont const &,int)" ([email protected]@@[email protected]@[email protected]@[email protected]) referenced in function "public: virtual void __cdecl MyClass::draw(class DzDrawStyle const &)const " ([email protected]@@[email protected]@@Z) MyClass.obj
Thanks!
