How is the typical trans (or texture) map applied to hair?
rbel_295e7c1d4crbel_295e7c1d4c Posts: 99
The trans file image is usually made up of a series of vertical strips of varying lengths with feathered bottom edges, not an image of the hair in its entirety. How is this applied to what can be a large number of hair segments?
  • Richard HaseltineRichard Haseltine Posts: 111,382
    edited March 2014
    Applied? By selecting it in the Surfaces pane for Opacity strength. If you mean why is it like that, modelled hair is usually made up of a number of overlapping sheets, which are unwrapped to lay together on the UV map and that's what you see when you look at a texture or opacity map.
