Should the HDRI Dome still be reflected if Draw Dome is off?
In rendering a scene with a lake of sorts, I noticed a strange distortion on the surface (attached). Draw dome is off so I expected only the light, alas.
In checking (using a mirror shader) the dome is clearly seen. (Also attached)
This may be a case of simple misunderstanding but should this be so?
1413 x 935 - 300K
1409 x 927 - 302K
  • Check the environment mode options, think 'scene' only is what you're after.
  • Scene only yields black. (attached).
    1417 x 925 - 105K
  • It renders both the sky and the ground even though both Draw Dome and Draw Ground are set to Off. There may be something I'm missing here...
  • HylasHylas Posts: 5,328
    If you select Dome & Scene and Draw Dome: Off  the skydome will still be visible in reflections.
    If you select Sun-Sky only  the reflection will show a plain blue sky and possibly the sun, depending on your angle.
    If you want absolutely nothing other than the lights in your reflections you should select Scene Only, but then you need to set up some other form of illumination (like a Distant Light for example) or you have no light at all in your scene and it will render black.
  • conscience73conscience73 Posts: 42
    edited January 2020
    Ah, okay. I figured. (Vaguely recall reading that somewhere too.) Thanks.
    Post edited by conscience73 on
  • If you are lighting your scene solely with an HDRI, everything you can see is the surfaces within your scene reflecting the light coming from the dome. If the surfaces are very shiny and reflective, they'll reflect what's coming from the dome. There's no such thing as "only the light", because the HDRI is only light anyway.
