is there a way to refresh transparency maps
right now in order for me to get my trans maps refreshed in daz3d i have to start a new scene and load the item and load the map, if i don't like the results and make alterations to the trans map.
i find it not refreshing in daz3d so to see my changes i have to make new all over again.
is there an easier way to do this?
In the Surface Pane Options Box (small Striped square at the top corner) should have a command to Refresh Images (or Ctrl + I)
Oooh! Thanks for that! I was having the same problem with Opacity maps... My solution was to call them xyx_OPACTIY_1, _2, _3, _4, ... and keep loading new ones until I got it right, and then call that one _FINAL. But it left me with a ton of relict files that I then had to remember to clean out (which of course I usually don't).
I did that when I started, it was ages before I found it. :)
awesome thank you so much
my pleasure aceviper64
