Daz 3 content in DAZ 4
Is it possible to use DAZ 3 content in DAZ4?
    Yes     you will find that some of the products may have updates to the latest Iray renderer,  but 3DL is still included as well. If you use DIM to download it should tell you if you have any updates.   You can redownload using either DIM or Connect    or manually,  and you cna find your purchased products in you Product Library  https://www.daz3d.com/downloader/customer/files
  • Yes, no and maybe.
    It's really going to depend on the particular content you're referring to.
    Scripts are straight out, there's been a lot of changes to DS over the years especially with the massive revamp in 4.5.
    Plug-ins are in the same situation, too many programming changes for them to continue work.
    Assets, e.g. clothing, sets, props, may or may not work the same, primarily due to changes in the render engine and shader options, so your resulst may vary from 3 results.
    And updates to the particular content may or may not be available.
  • LeanaLeana Posts: 13,498
    DS3 plugins won't work in DS4, but some of them were updated with a DS4 version.
