Wounds Visiblity with decals
LoonyLoony Posts: 1,817
edited January 2020 in The Commons
Hoi!
I found this:
https://www.daz3d.com/wound-makeup-artist-for-genesis-8
and it say:
That it use decals.
But... so far I learned it, is a decal... just in iray visible and... does not fit to a body? So when I add the wound I have to add it again and reaarange it again, when I change the scene? I mean, it would look weird when the wound is moving during a comic O_o
Post edited by Chohole on
  • lilweeplilweep Posts: 2,879
    edited January 2020
    Iray decal nodes are only visible in iray preview and render (i believe).  In order to add/make a decal, the decal node must be parented to something (i.e., figure, figure bone, or object).
    Because the node can be parented to a bone of the figure, the decal should follow the parent bone moderately but only to a certain extent so i think you may need to manually adjust between poses.
    Post edited by lilweep on
  • LoonyLoony Posts: 1,817
    Hmm okay, thanks for your Feedback, I will think about it, if I get it, with my actual PC are decals/iray live views a slow process... so placing a decal is very ... annoying^^
  • Matt_CastleMatt_Castle Posts: 3,305
    If you need the wounds to be consistent between pictures, then you may want to use the L.I.E. functionality instead (not having it, I don't know how the LIE functionality is set up, but LIE certainly isn't inherently a 3DL only feature, so it may work fine with Iray), as this will apply it on a UV level rather than projecting it based on the geometry.
    Decals certainly have their uses, but as with all things when it comes to CG rendering, they also have some limitations.
    I used the Layered editor sometimes and that is not bad (I wish it would have some Gimp features like drawing, an eraser and other basic paint tools...)
