How to use a Mask?
I have converted a 3DS bottle to an OBJ. I can import the bottle's labels but the liquid inside doesn’t show through the surrounding glass. There is a mask image that I can use, but I don’t know how to use it so the liquid shows through the glass. Help!
  • GordigGordig Posts: 10,687
    If you already have the mask, all you should need to do is go to the bottle’s surface settings and plug it into the Cutout Opacity.
  • LD1LD1 Posts: 172
    Thank you that did work - I can see the underlying sauce. Unfortunately my labels seem to hang out in the air since the bottle is now invisible. The only idea I had was to duplicate the bottle, reduce its size ever so lightly, and then make it glass to get everything to look right. Anybody out there have a better way?
  • felisfelis Posts: 6,187
    Create a geo-shell for the bottle, and use that for the label.
  • LD1LD1 Posts: 172
    The geo-shell woked!!! Thank you felis!
