Some questions about tattoos in DAZ Studio
chrishytangchrishytang Posts: 0
First: How do I delete tattoos? I can't right-click anything...
Second: How do I use the Layered Image Editor? Whenever I select it from the Surfaces tab, I don't see a skin map, and every time I switch back afterwards to the original scene (close the LIE), the figure I selected has blank white skin. No eyes, no color. It looks like one of those clothing store mannequins you see at the mall.
  • Richard HaseltineRichard Haseltine Posts: 112,021
    To launch the Layered Image Editor for an existing map, you pick it from the image selector of the property using the map - the little box to the left of the slider in the Surfaces pane. If the tattoo is applied through LIE you should be able to delete its layer there.
  • JaderailJaderail Posts: 0
    With the Figure selected open Surfaces then pick a surface area and use the Diffuse (for a tattoo) drop down to open the LIE.
    486 x 716 - 46K
