face transfer failed to load a Genesis 8
Hi,
I have Daz Studio 4.12.0.86 Pro Edition
I have genesis 8 male & female starter essentials installed
But, in Face Transfer, when i click to generate it say :
"face transfer failed to load a genesis 8 figure. Could not locate the genesis male 8 file : data/Daz3D/Genesis 8 male starter essentials/Utilities/Genesis Male whith basic wear.duf"
do i have to remove and reinstall genesis 8 ?
or do i have to manually create folder and file ?
  • LeanaLeana Posts: 13,598
    I don't know when you installed them, but Face transfer requires the latest update to Genesis 8 Starter Essentials, so it might be worth the try to reinstall them.
  • no update is  avalable on DIM
  • ThorneThorne Posts: 179
    edited April 2020
    Notice the path. I'm getting this error because my library is installed on a separate drive, something we should be able to designate but I've not seen how to do that yet. You can work around by loading the Genesis 8 figure first.
    Post edited by Thorne on
  • I had that just the other day. Uninstall the Genesis 8 Male and Female Starter essentials from DIM and reload and DIM should find them again. They added a clothing top and bottom duf to the female base so your newly created face is not on an unclothed body. Apparently, not a big enough change to push out an update, unless you want to use the Face gen.
