Viewport Jumping too Fast
johranshadi
I installed daz on a second, virtual, computer but viewport is moving too fast that makes it impossible to control and adjust to specific angle. So any mouse rotation or dragging around the scene to view the objects, whether in perspective or a camera mode , causes uncontrolled jumping of viewing angle.
I should also note that Daz works fine on my main computer.
And another question, my virtual computer (provided by Shadow) shows different IP addresses and different country. I did submit a ticket about that to avoid getting in trouble. Is there anything specific about that in the TOS?
Thanks!
Edit -> View -> Increase/Decrease movement speed :)
I don't know about the IP problem, but I guess many users have VPN, and maybe that's not so different
I get the exact same overshoot in the viewport when I log into my pc using a remote administration tool like teamviewer or anydesk.
I suspect that the mouse commands have a miniscule lag in them (as expected since your'e not actually sending real time mouse commands, but rather data packets through a few abstracted layers) so the viewport keeps updating until the next mouse movement command comes along.
You can, as LenioTG said, increase/decrease movement speed to compensate.
You are a life saver...it worked thanks!
That makes sense! Thanks for bringing that to my attention and I'm glad I'm not the only one with that problem. Decreasing movement speed did take care of the problem. Thank you!
