G8 Morph making - do I need to use "Dev Load"?
Most of the YouTube tutorials I see use the basic G8 figures for making new morphs, base resolution no lashes etc. But the G8 Dev Load is said to be intended for developers making morphs & content.
So - which do I NEED to use? Why/When?
Thanks!
  • MimicMollyMimicMolly Posts: 2,379
    The Dev Load is the same figure, except it loads without textures or eyelashes. Also, it contains the deformers that separate the head and the body, for morph making, but this can be applied to the default load with textures.
    I prefer the Dev Load, because I like to start out with a texture-less figure and see how the shape with its HD details look like before applying the textures. But my workflow is the same one I've had since the first Genesis which loaded without textures. It doesn't matter which you use, it depends if you like working with a textured figure with eyelashes, or untextured without eyelashes.
  • Thanks Molly! smiley
