A curious Passage - Gate control?
SoulUnit
Hi there, I have purchased Jack Tomalin's "A curious Passage" and have looked high and low and can find no way to open the gates although it clearly shows in the store the gates will open. I did the Daz Install Manager install so I assume everything was placed in the correct folders. Can anyone point me in the right direction? Thanks!
Post edited by SoulUnit on
Select one of the gates and the "Gate_Open" control (actually a renamed Rotation control) will appear in the Parameters tab under General>Transforms>Rotation. Note that if you select both gates at once then use Gate_Open, they'll open in opposite directions.
Great thank you!
