Reality 4 does not appear in Plugins or Render Tab
Hey Guys,
I've bougt Reality 4 but i am not able to use it.
iMac Pro 2017
3 GHz 10-Core Intel Xeon W
64 GB 2666 MHz DDR4
Radeon Pro Vega 64X 16 GB
Reality 4.3
DAZ 3D 4.11 Pro
I tried the the tips of the Productpage but nothing workt. The Plug In File is in the right folder, The Lights and Probs are also there but in the Render Tab and in the Plug In Tab nothing - I can run Lux Render and Reality manually from the Application folder but then i am not able to render. Any help or idea? I cant register at the Pret a 3D Support Forum becaus of an error of the page.
Thanks
1004 x 1198 - 289K
772 x 376 - 170K
1240 x 1054 - 197K
1658 x 872 - 450K
    There's a dropdown menu at the top of the Render Settings tab, for selecting the render engine (e.g. 3Delight or Iray). When you get it installed, that's where Reality appears.
  • SimonJMSimonJM Posts: 6,101
    Not for me, Reality only appears uder the Render menu  LuxRender (a different way of linking DS to LuxRender) appaers in the Render Settings dialog though.
  • The same for me. I installed it like the installer asked for.
    I meant, of course, "LuxRender via Luxus" as the Render options dropdown item to specify render engine.
  • KitsumoKitsumo Posts: 1,222
    Did you register it? I can't remember exactly where but you do have to enter a serial number at some point.
    Not registering shouldn't stop it appearing in Help>About Installed Plug-ins.
  • PlatnumkPlatnumk Posts: 682
    When you installed Reality 4 did it ask you to put in your Name, Email Address, Order Number & Serial Number?
