Changing Duration of Animated Shot?
DekeDeke Posts: 1,636
edited January 2020 in New Users
I've set up a shot in Daz with a lot of different items interacting. Looks good, but everything happens too fast. Is there a way to just stretch out all the keyframes as a whole like 200%?  Make it twice as long to slow everything down, but keep the interactions?  Is that a Graphmate task?  I have Graphmate but never dived into it.
Post edited by Deke on
  • The default setting in animate is 30 FPS (frames per second). All you have to do is set it for 60 FPS and it will make twice as many frames to do the motion - easiest way is to switch it in the timeline tab in the little box on the far lower right (it can also be done in keymate) ... which can then be turned into a longer animation by setting 30 FPS in whatever program you are using to put the image series together.
