Puppeteer problems.
Robinson
I may have the IQ of a small squirrel and as a consequence am doing something wrong but does Puppeteer actually work correctly in 4.12?
User expectation: my expectation with puppeteer is that it records on a dot only the changes made whilst the layer is selected. So for example, I take a G3 figure in a bind pose and add a dot to layer 1, pose the arms and add another dot. Then I create a second layer, change the expression and add a dot there. When I go back to the first layer and click either one of the dots, I don't expect the expression to change. Yet it does. Each dot appears to record the entire pose and all expressions.
What am I missing? And if that's how it works, what's the point of a layer?
I have discovered that when in Preview mode, setting the cursor position near each dot on either layer does what's expected, i.e. layer 2 expression remains on the figure wherever I put the cursor on layer 1. I'm talking about clicking the dots themselves in Edit mode.
As a UI designer, a general rule of thumb I follow is if I can't explain what a UI element does in a single, reasonably short sentence, it has no place being there. Can anyone do that for Puppeteer layers? I am finding it quite baffling.
