IVAN 7 HD Add-on
Hello everybody. Months ago I bought Ivan7 and the HD add-on. Now I have tried to reinstall him with his HD and while loading the HD it gives me an error (see the log here below). I can't find a solution. Any suggestion? Thanks!
2020-01-12 17:33:50.839 Loaded file: ivan 7.duf
2020-01-12 17:33:51.004 Loaded Morph Deltas in 0 min 0.0 sec.
2020-01-12 17:33:51.004 Loaded file: FHMIvan7.dsf
2020-01-12 17:33:51.025 Loaded Morph Deltas in 0 min 0.0 sec.
2020-01-12 17:33:51.025 Loaded file: FBMIvan7.dsf
2020-01-12 17:33:51.028 Loaded Morph Deltas in 0 min 0.0 sec.
2020-01-12 17:33:51.028 Loaded file: PHMMouthRealismHD.dsf
2020-01-12 17:33:51.036 Loaded Morph Deltas in 0 min 0.0 sec.
2020-01-12 17:33:51.037 Loaded file: PBMNavel.dsf
2020-01-12 17:33:51.379 Loaded image ivan7armmapd_01_1004.jpg
2020-01-12 17:33:51.446 Loaded image ivan7mouthmapd_01_1005.jpg
2020-01-12 17:33:51.688 Loaded image ivan7facemapd_01_1001.jpg
2020-01-12 17:33:51.918 Loaded image ivan7legmapd_01_1003.jpg
2020-01-12 17:33:51.999 Loaded image ivan7eyesmapd_01_1007.jpg
2020-01-12 17:33:52.228 Loaded image ivan7torsomapd_01_1002.jpg
2020-01-12 17:33:52.288 Loaded image ivan7eyelashesmaptr_1006.jpg
2020-01-12 17:34:02.496     C:/Users/davro/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_30854/people/genesis 3 male/characters/ivan 7 hd.duf (1,1): Syntax error - expected '{' or '['
2020-01-12 17:34:02.501 Error reading file, see log for more details.
2020-01-12 17:35:50.357 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
  • NorthOf45NorthOf45 Posts: 5,823
    That kind of error can only occur if the file has been damaged, either in the archive or on disc. Test the archive if you have a utility like 7-Zip or WinRAR. Or just try installing from a fresh download.
    Thank you for your reply. I have installed by using the DAZ connect, and afaik it should have downloaded directly from the DAZ server. Am I right? Thanks.
  • Made it!
    I just manually downloaded the IVAN HD add-on zip file, found the duf file and replaced the one that was in the connect folder. Thanks!
    Something is wrong somewhere with the Connect version. I don't use Connect, but everything should be the same. Maybe a help ticket would be needed to clarify. Anyone else have the same problem?
