unseen in aux view
is this a known issue that if i make something unseen in the scene
n the aux view its still there to be seen ?
  • Richard HaseltineRichard Haseltine Posts: 111,296
    edited January 2020
    That should not usually happen - what tool is active, and which is the active viewport? Are both using the same preview mode? How was the item set to be unseen?
  • RuphussRuphuss Posts: 2,631
    main view port is texture shaded
    aux is iray
    making  the environment unseen by clicking the eye
    but its in a group
    may be theres the prob
    just did some testing
    aux view does not react on nodes that are in a group if you make them unvisible
    may be some work on the code could help here dear daz devs
  • That is odd, and I'm not sure how it could happen (if it is woring as exepcted in the same Iray preview in the main viewport) so it may well be worth opening a ticket for https://www.daz3d.com/help/help-contact-us
  • VisuimagVisuimag Posts: 578
    I've seen this behavior before. Something not disappearing in Iray (Aux) while I've hidden it in the Normal Viewport. It's very similar to issues I face with decals (though these also cause glitches and stuff too).
