black hair-silver hair
when rendering with "sun/sky only" black hair gets grey/silver color
how to avoid this so the hair stays full black even in full sunlight
taking out reflections helps but not enough
any thoughts ?
  • try changing the "glossy color" to an almost black.
    surfaces(tab)>glossy color.
    May need to change other settings as well depending on the particular hair's shaders settings.
  • RuphussRuphuss Posts: 2,631
    thank you but did this already
    i am talking bout mathilda hair which i like very much
    but its hard to get a pure black in pure light
  • DrunkMonkeyProductionsDrunkMonkeyProductions Posts: 1,311
    edited January 2020
    if this is the hair you're referring to
    https://www.daz3d.com/matilda-hair-for-genesis-8-females
    It's the "Top coat color" that's causing the issue.
    I also noticed that none of the texture maps are an actual black, so you might want to drop those and switch the "diffuse color" to black.
    Post edited by DrunkMonkeyProductions on
    managed it with top coat weight to 0.03
    top coat color to black would do the job also, you are right and thank you
    but with top coat weight you can dial a small reflection light
