Shrunken model grows when I export it?
I have a character model. I shrink it with the scale meter, but when I export it, it grows back to its original size. Why is this happening and how can I fix it?
  • nicsttnicstt Posts: 11,715
    edited January 2020
    What percentage are you exporting it at? (I mean under the export settings.)
    Where you import it to will also have an effect.
    Post edited by nicstt on
  • RobinsonRobinson Posts: 751
    I would strongly advise avoiding exporting anything that isn't "100%" in your character's scale parameters.  It'll cause all kinds of problems further down the line.  If you have a pipeline going, FBX for example, into another piece of software, always scale the figure at the last possible moment.  E.g. my character is actually 110% overall scale in Daz.  I export at 100% and import into Unreal Engine (through Maya).  Everything is multiplied by 1.0, which means there's no monkey business needed anywhere in the pipeline to maintain the scale.  When I put the figure into the scene, only there do I change the scale to 1.1 (110%) for the correct size.  Animations can be imported at 100% and shared with other characters with no change needed.  They can be retargetted to scaled figures at some later time.
    The reason I give this advice is so you keep your sanity when trying to understand at which point in the pipeline the scale actually occurred.
