p5 or pp2?
I am sorting through some older content files and am deleting duplicates as I go, so if one file is more up-to-date than another, I'll just get rid of the older files. Since I'm not a poser user, which file is newer or better for az? p5 or pp2?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,764
    edited January 2020
    for materials in the pose folder PoserPro ones always a better choice than Poser5 as the materials in 5 were mostly not compatible with DAZ programs
    the file itself not big though, mostly a text file they all reference the same maps
  • WillowRavenWillowRaven Posts: 3,787
    these are props ... Same rule? PP better than numbered?
    I imagine so, I would always load the pro one, some have textures so would be the reason
  • BejaymacBejaymac Posts: 2,013
    Doesn't matter what the file type is it's the Material settings inside that count for a DS user.
    Pro Pack (Poser 4.5) first as it uses JPG for bump, then comes P4 and it's BUM files for bump, after that you take your chances with the rest of it.
    We say PP then P4 because DS can only see the P4 material settings in the files, with P5+ there is a pretty good chance that no textures will be loaded into DS, purely down there being nothing in the P4 material part of the file for DS to load.
