can someone please help me with md problem imported back to daz
when i make clothing for genesis 8 characters
and then import it back to daz and pose it the
clothing stretches and i was wondering if someone can walk me through this and fix this   thanks so much
  • Cris PalominoCris Palomino Posts: 12,963
    Have you done it successfully before? What steps do you take? Can you show screenshots of what's not working?
  • What do you mean by stetching? Are you working on a base Genesis 8 Female or are you using the Victoria 8 shape?
  • lasagnamanlasagnaman Posts: 1,001
     hi ty so much for responding yes its only the genesis 8 cause the default pose is not in  t pose like genesis 3  is
    iam working in the base one
  • If you could post a screen shot it might help to see what the issue is.
  • barbultbarbult Posts: 27,495
    I assume you have used the Transfer Utility to rig the clothing to G8F. That creates a basic weight map for the clothing, but you may need to refine it with the weight brush tool. You also probably need to create Joint Control Morphs (JCMs) for bone rotations. Poses like raising the arms above the head almost always cause ugly mesh distortions in the underarm area. DarkEdgeDesign has a couple useful MD/Daz tutorials in the Daz Store.
    As Richard and Cris said, some screenshots of your problem would lead to better diagnosis and advice.
  • AsariAsari Posts: 703
    edited January 2020
    Rigging the imported mesh causes all kind of problems, like @barbult said. If you aren't animating, it is way easier to drape the cloth to your desired pose and then export the mesh from MD to Studio. The clothing piece isn't very flexible and you have to do this for each individual pose but proper rigging takes time, too ... and skill (which I myself definitely don't have).
    But then of course if you want to create clothing pieces to sell via the Daz store, that's an entirely different topic.
    Post edited by Asari on
    you peaple are so awsome ty so much for willing to help i will post screenshots when i get home so you can help me thanks so much again
