How to know what files are absented?
iSeeThisiSeeThis Posts: 560
I know that some files/products are absented because I install them with DIM to 2 machines and the installed number are not the same. Just try to find it in manual but I must miss it if it's there. Thank you.
    I don't really understand what you mean by 'absented'.
    Can you explain a bit more fully what it is that you are having trouble with?
    Are you saying that files are missing in DIM, or is it just a Smart Content thing?
  • iSeeThisiSeeThis Posts: 560
    Yes, Jimmy. Some files missed in DIM installed tab. I would like to have a way to check what those file are.
  • JaderailJaderail Posts: 0
    DIM keeps Track of what was installed before so If you install some to one machine those will not show as NEW to install a second time. You need to Copy all Files from DIM before you Install to the First machine so your PC's stay in step. Never install to the online Machine first always do it second, after you copy the files for the other machine.
    Thank you Jaderail. That's very helpful.
