Clearing dforce simulation on one item while leaving the others?
Sometimes I'll use more than one dforce item for a scene, let's say a blanket and some hair. I run dforce on the blanket, and get it just how I want, freeze sim, but then I need to simulate the hair. The blanket stays, but I don't get the hair right, so I've got to clear siumulation and do it again... but that will reset the blanket, even with freeze sim on.
At this stage, when I get something with dforce posed right and something wrong, I just reload the scene to where the blanket is right so I don't need to simulate again. Is there another way? Is it safe to remove a dforce modifier from something already posed? Thank you!
  • If you want to rerun the simulation on the hair just do so, that will clear any existing simulation.
    You're right, but that reminds me, the reason I use clear simulation is so that I can resposition the figure or anything else around the item's cleared state. Oftentimes I would not remember where the hair or cloth would start if not for clear simulation.
  • Yes, you can do this. Select the item(s) you want to clear, Then in the Edit > Object > Geometry menu there's an option to "Clear dForce Simulation from Selected Item(s)."
  • AnimAnim Posts: 241
    You can also right click on "Simulation Setting pane ..." to reset simulation of only the selected items instead of all of them.
    826 x 371 - 108K
    Sorry double post.
    Thank you both! I'll try these out next time I need to.
  • hansolocambohansolocambo Posts: 649
    edited April 2020
    Thanks @chris-2599934 and @Anim, super useful.
    Post edited by hansolocambo on
    fantastic, was looking for a solution to this issue.
