rules for using a Geoshell?
MistaraMistara Posts: 38,675
it's a totally new concept. lol
does it inherit bends?
is it anything to do with how volumetrics works?
  • Richard HaseltineRichard Haseltine Posts: 112,003
    A Geometric Shell is like an instance, a live copy of the figure or prop it is made from. It differs from an instance in that it can have different surface settings, including UV Set, so you could use it to create a range of items with the same shape but different colours (crockery on a shelf, for example) or you could apply an overlay such as a water or tattoo to it, with an opacity map, even if the overlay used a different UV set from the base texture.
    so if you repose the original, the geoshell will move with the pose or does it need to be recreated?
    does Cararra have geoshells?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,819
    edited February 2014
    no
    but it has replicators
    a geoshell prob more like a duplicate which carrara can do with props
    for figures you need Fenric's tree duplicate plugin
    or drag your grouped figure and clothes to the browser, save, then drag multiple copys of that saved figure group into the scene
    The shell will update, yes. The shell itself is unposable - you can move, rotate, and scale the whole thing as a unit, and you can apply a Push Modifier (in fact one is applied by default, to make it easier to use as an actual shell surrounding the original figure for overlays which is its initial purpose)
    hmm 'Error Message: Unable to receive your submission at this time'
