Anubis Genesis 2 Male to Genesis 3 Textures Help?!
Hello,
  I wanted to create Genesis 3 Male Anubis from Genesis 2 Male. So far I got the morph but when I tried to add the texture from Anubis to Genesis 3 Male it didn't work. I got all the legacy UVs products for my Daz3D and it still didn't work out. So when I look at the UV Set on the Genesis 2 Male one it said that it has Anubis UV and when I look at Genesis 3 Male it doesn't have it even though I converted it from Genesis 2. Can someone please help me this problem? How do I copy the Anubis UV from Genesis 2 to Genesis 3? Thank you
1800 x 1440 - 2M
  • LeanaLeana Posts: 13,501
    The legacy UVs product won't give you Anubis UVs, only the base G2M one, and there's no way to simply "copy them over". You would need to convert the textures to G2M UVs to use them on G3M.
    You may be able to do this with the Map Transfer feature in DS.
  • You would need to use the Map Transfer utility in DS to convert the maps to work on the bse Genesis 2 Male UVs, or any other UV that you have supported on Genesis 3.
