Duplicate Formulas Detected Error
Hi I've already done some searching and found the issues are relating to Genesis 8 morphs but I have a problem resolving and wonder if someone can shed some light on this.
The other day I ran the Riversoft Gen 3 to 8 Character converter tool and since then every scene I have that has a Gen 8 figure in it throws up this Duplicate Formulas error when loading it up. I've also noticed that render times have increased dramatically. This also occurs in any scene that has a Gen 8 figure created before I ran the converter
I've uninstalled Daz, deleted all content and deleted all hidden Daz folders in Appdata and everywhere else (I'm Win 10 64bit) and gone through the registry.
Rebooted and Reinstalled everything but still get the error when opening a scene with a Gen 8 figure. The only thing I've not done is hooked up DIM online for product updates (all my install packages are stored on another drive)
If anyone can point me in the right direction I'd be very grateful
Thanks
Jay
Any change to render times is not going to be a direct result of the duplicate formula errors.
This probably means you now have two morphs with the same name that are each controlling a sub-property with the same name - for example, perhaps you converted a Genesis 3 Character that already had a Genesis 8 version. The issue affects the base figure and every character derived from it, regardless of when they were created (DS checks and loads all the morphs for the figure). The fix is to identify the problem morph and rename or remove one of them - check Help>Troubleshooting>View Log File, searching backwards from the end to find Duplicate, and you will get one file for each problem - from that you may eithre immediately see the issue or you will at least know the name of the othr property involved.
Did you unnstall and rinstall content? Tis is a content issue (in fact, probably a clash between wo bis of content) rather than an application issue. In any event that would be unduly drastic. The first step is to figure out what is causing the clash.
This happens a lot for people. I'm pretty sure that this is an issue you'll need to sort out with in each scene that has the problem. I know I've gotten rid of the duplicate formula (morph) only for it to rear it's ugly head again later. Find it in the log file. Search for it in your Conent Library with your computers Search.. Remove the version you don't want (it isn't a naming issue, it's the morph, even with different names if the morph does the exact same thing thing it will flag) and save the scene. It will come back if other scenes have that problem. It drives me nuts too but it's just what happens. Something you have to deal with. I would never reinstall Daz unless I'd exhausted all other issues first. Search Google for the issue with 'Daz forum' in the search. You'll usually fine the problem. Try a few searches with different key words too. If not then just ask. There's someone who will help you sort it. Even if it's only them sparking an idea so you end up solving it for yourself.
It's good to talk. :D
