DAZ 4.6 Cartoon Shader? Is this all there is?
sjokc_7580a1ef2bsjokc_7580a1ef2b Posts: 0
My default shader for rendering is Cartoon. It's the only shader available. Is that all DAZ 4.6 has for rendering or do you have to purchase other rendering shaders? I thought there used to be realistic shaders that came with previous versions.
  • KinichKinich Posts: 941
    In the render settings Pane (Tab) there should be a 'Render Style' box with a drop down list that should have 'Default' & 'Cartoon' options available. See the screen-shot below, this option should be present in both General & Advanced views.
    364 x 598 - 97K
  • sjokc_7580a1ef2bsjokc_7580a1ef2b Posts: 0
    Thanks. Its been over a year since I've used DAZ Studio and having to relearn a few things. I was seeing it as the default option is Cartoon not that there was a default and a cartoon shader. Stupid I know. Thanks for your help. Take care.
  • TjebTjeb Posts: 507
    If you are really into creating cartoons, I suggest you follow this thread:
    http://www.daz3d.com/forums/discussion/36728/
  • DZ_jaredDZ_jared Posts: 1,316
    Just so you are aware, choosing the "Cartoon" shader in Render Style will replace the DAZ Studio Default Shader with the Cartoon Shader on all surfaces that have the DAZ Studio Default Shader applied. If a surface uses a custom shader then it will be ignored and won't have the Cartoon Shader applied.
