HD Genesis Rendering Problem!
Optimus ShepardOptimus Shepard Posts: 196
Hello,
I got a little bit of a problem with HD Genesis. For example, RawArt Creature of the Depth which is the coolest art/creature I love it but the rendering is too slow than usual and I didn't even use any light for it. Could someone please tell me how to make it faster for both non light and light effect? Thank you.
  • SorelSorel Posts: 1,434
    Renders with HD applied take a little longer to render I believe.
    When you use HD morphs for Genesis or Genesis 2 it is subdividing the figure three times. For Genesis that means a whopping 1.2 million polygons compared to it's otherwise more manageable 75,000 polygons. In short, there's a lot more maths needed to calculate the figure, so it will inevitably take considerably longer to render.
    If you're having prohibitively long render times, it might help to post your system specifications. Obviously, the more powerful the PC the fewer rendering issues you're likely to have.
  • JaderailJaderail Posts: 0
    And even when you THINK your not using a light you are. Its called the Head Lamp and is from just above the Render Camera or near center of a view. That means all the Lighting calculations for the mesh as well. More detail more calculations.
