Iray Distance Fog
Hi, could anyone please  tell me how do I use Iray Distance Fog product - https://www.daz3d.com/iray-distance-fog ? I can not find it neither in my products nor in cameras tab?
thanks a lot!
Momir
  • barbultbarbult Posts: 27,635
    Iray Distance Fog shows up for me in the Product section of Content Library and Smart Content. The camera is categorized as a Prop and is named "KADF Fog Camera". The product contains an instructional PDF file named "KADF Handy Guide". If you can't find these, it may be that the product isn't really installed, or is installed into a location that is not a mapped content library inside of Daz Studio. Did you install it with DIM (Daz Install Manager)? If so, does it appear in the Installed tab of DIM? If so, right click on the product name and select Show Installed Files from the pop up menu. That will show you where it is installed on your computer. Is that location a mapped content directory in Daz Studio?
    Report back, and we can go from there to figure out the problem.
    563 x 385 - 45K
  • The fog is actually a prop, it should appear in Products>I in the Content Library pane
