Need Help with DIM "How about a fresh start?"
So I just watched the videos on "Manage Your 3D Content with Install Manager" and followed exactly what they did on "How about a fresh start." That is I de-installed Alruna as well as the MetaData with assumption that once de-installed it would then be available in the DIM. However, it did not show up. I don't want to move forward with using the DIM if it's not going to give me the option to re-install. Any ideas about why DIM is not showing or allowing to re-install.
    edited February 2014
    If you installed Alruna with the DIM, then, when it uninstalls it again, it should put it in the Ready to Install tab. If you didn't use DIM in the first place, it wont be there. If you delete the files after downloading, you will need to redownload it again.
    All of your purchased content should be available through DIM, so just install it from there.
    Post edited by JimmyC_2009 on
  • edited December 1969
    Thanks, that helped! I just read that all installs have been converted. Got it back installed through the DIM online.
  • frank0314frank0314 Posts: 15,116
    A great majority of the stuff from DAZ is converted but there are some older stuff that hasn't been converted yet.
