Help with removing "saved content"
in The Commons
hello guys i need a little bit of a help with removing saved content, i'm having issues with deleting 'saved content", i was deleting some "not wanted content like "too high poly count stuffs, then when comes to "normal daz products no issues" but when i try to delete "for exemple a hair which i used riversoft hair converter or a cloth converter o i have converted some cloths to fit other gender or stuffs like that when i just delete the base file, it's still appearing in the "daz" as a unknow product but in some cases it's still working even after i removed the original product, how i can proper remove those files to they really vanish from my daz???
Deleting from within the UI will dlete only the fle you delete, not any assets it used (otherwise any time you deleted a scene you'd have to reinstall the content). If you want to clear out an entire product you need to manually delete the files, then delete the product itself in DS (right-clck menu).
