Standard map naming?
Alric
I'm working on converting some poser figure maps over to iRay and I've run into a question on how the maps are labeled. Rendo is down right now so I can't ask the merchant, I'm hoping that this nameing might be standard and others know what they mean.
The maps have the standard color map and then several other maps.
I know that "B" is the bump map and "D" is the displacement map, but what are A, G, and S? I'm guessing that G is for glow and I'm using it as an emission map.
Eric
G could also be Glossy, but I'd expect S to be Specular. A might be Ambient, which wouldn't be used in Iray (unless you wanted to use it for emission colour or strength on a light-emitting surface). Unfortunately there are no hard-and-fast rules - sometimes D is diffuse, the base colour, instead of displacement, and the Poser Firefly render engine is more like 3Delight than Iray so you may not be able to get a sensible match for everything anyway.
I've just been playing around with which ones to use and the S maps look nice as Glossy. I was thinking of using the A maps for translucency. These D maps are definitely displacement. The G maps are working excelently as emission maps.
If you have poser installed, you can apply the character presets and see what maps are going where.
