Dynamic Clothing Control for Daz 4.6
eiliestleiliestl Posts: 100
I've been trying to install the Dynamic Clothing Control for Daz 4.6 .But It states that it cannot find my Daz folder,and yes I'm useing Daz 4.6.
And without useing the DIM how can I install it . That thing isn't working right either. Somebody please help me.
    What is the EXACT name of the file that you are trying to install, and are you running the latest version of DS4.6 (4.6.2.118), you can find out by going to Help About DAZ Studio. Did you download the correct bit depth for your version of DS, i.e. 32 bit or 64 bit.
    I have just downloaded the latest version of the Control, and it is called DS4_DynamicClothingControl_1.3.2.118_Win64.exe So, it is important to be running the correct version of Studio.
  • PantherTOPantherTO Posts: 0
    It sounds a bit like the following post. Response #6 by Richard Haseltine (top right of each post) in the following thread might help.
    Dynamic Clothing Control “The installation path for DAZ Studio could not be found”
  • eiliestleiliestl Posts: 100
    edited February 2014
    I am using the DS4_DynamicClothingControl_1.2.2.40_Win64
    And for my Daz 4.6.1.33 pro 64-bit
    Post edited by eiliestl on
  • JaderailJaderail Posts: 0
    And for my Daz 4.6.1.33 pro 64-bitThat will not WORK both versions must match. Only .118 plugin works with DS .118 and the same for all other versions. Same version of BOTH are needed.
    That version will only work in DS .40
    Post edited by Jaderail on
    Ok is Daz .40 the most recent ?
  • fixmypcmikefixmypcmike Posts: 19,740
    No, .118 is the most recent. Both DIM and your Product Library will give you the .118 version.
  • magikmagik Posts: 2
    I have the same problem...I am using the .118 version of DS4.6 but the dynamic control file I am being given, both by DIM and my Product Library is 1.3.3.50 ???
  • SimonJMSimonJM Posts: 6,108
    edited June 2014
    The last two numbers of the verrsions should match, so from what you say you have the latest DCC control, but a down-level version of DS, so should get/install the 4.6.3.50 version of DS.
    Post edited by SimonJM on
  • Richard HaseltineRichard Haseltine Posts: 111,992
    .118 was most recent in February - we are several version son since then, and although older DAZ Studio 4.5 plug-ins should work in newer versions of DS the reverse is not always true.
    As Noted the last digits are the important part. For DS4.6.3.50 you want Dynamic #.#.#.50 for example. And be sure the Bit versions match as well 32bit to 32bit and 64 to 64.
    OK, sorted! The problem was that I was checking for updates from the Preferences menu inside DS and it was telling me that no updates were available so I (wrongly) assumed that I was running the latest version of Daz Studio! I checked on the website and found a newer version. Thanks everyone.
  • radio.londraradio.londra Posts: 2
    I have a similar problem. I am using the 4.6.3.52 version of DS4.6 and I get DS4_DynamicClothingControl_1.3.3.52_Win64.exe.
    If I try to install by Download manager and nothing happens, and if I download and run the .exe on my PC I get the following message:
    I checked the dzInstall.ini file but all seem correct.
    Somebody can help me? Thanks!
