Strand based hair, geometry shells, and saving - solved.
gitika1
I have been working with an older model and learning strand based hair. After reading that others use a hair cap so that strand based hair can be saved , I thought a geometry shell would work the same. I add the shell and then the hair. I saved the geometry shell using File-Save as-Wearables preset. I made sure to include the materials. However, whenever I try to apply the shell to another bee, DS crashes. Any clues to what I am doing incorrectly?
DS does not like loading strand based hair when the viewport is in iray mode.
1300 x 1300 - 1M
Post edited by gitika1 on
No use geoshell. It is not the same as haircaps which are made with real mesh. That's a lovely bee btw.
If this is just for yourself you can copy out some real mesh [using a modeler] ... if it's intended for redistribution, then make a "beecap" out of real mesh. That can be added then to other bees.
