Installed Latest Update - them Problems
Hi,
Daz was working great,
I downloaded the latest update of 4.6 via Install Manager - which does not show on the list of things installed - restarted the program & find that the area that shows content library, parameters, render setting etc is whited out, and very difficult to use.
How do I sort this please?
It sound like you may have had DS open when installing the new version.
At any rate, you will need to uninstall and reinstall again. If DIM does not show it as installed, then you can't uninstall it using DIM I think.
You may need to download DS form your My Account > Product Library area. The manual installer should work fine.
It was open when the new version was downloaded.
Will I have to do any manual setting up if I uninstall and re-install?
OK I tried it & it worked fine thanks for the advice
Glad, it's working for you.
The content is not affected at all, nor your layout by reinstalling, as I'm sure you have discovered.
