Making a Wet, Waxy, or Oily render
TsuzuraTsuzura Posts: 119
How do I make the model in my render get a more of a wet/waxy/oily skin?
For skins I have:
IIV3
Lily Rose
Beautiful Monsters: LucreZia VFour Poser and DS
For rendering I have:
3Delight
Reality 2
  • srieschsriesch Posts: 4,243
    I'm not an expert in this area, however I would suggest experimenting with different values of the "Reflection Strength" parameter in the Surfaces(Color) pane, as a wet surface would have more reflection.
  • BarubaryBarubary Posts: 1,233
    I would go with the Specular settings first. Increase the Glossiness, use a brighter Specular Color and for 3Delight also increase Specular Strength.
    looking forward to seeing some oiled up figures :)
  • KhoryKhory Posts: 3,854
    Waxy tends to come with high Sub Surface Scattering settings. The AoA SSS shader is most likely to get you that effect easiest.
  • nobody1954nobody1954 Posts: 933
    Use subsurface scattering with indirect lighting properly, and you get a waxy look. There's a script that makes this easier in Poser. Still learning how to make Daz do it's thing, myself.
