Ginger Nip Slip
DickDastardlyDickDastardly Posts: 0
Just bought the new Ginger character for Stephanie but the nipple textures don't seem to line up properly with the geometry. Have I screwed something up or are others seeing the same problem? (and if so, can we expect a fix?)
Cheers,
Mike
  • Richard HaseltineRichard Haseltine Posts: 111,325
    Make sure you are using the right UV set - if you don't have Stephanie 6 and the textures are made for the S6 UVs you may not be able to get them to work, similarly if they use the V6 UVs and you don't have Victoria 6.
  • DickDastardlyDickDastardly Posts: 0
    Ah thank you, it was the UVs that were the problem. (I'd loaded her by double clicking the actor in the Smart Content tab and assumed that that would also automatically select the appropriate UVs but apparently not - after selecting Stephanie's all is correctly aligned).
    Cheers,
    Mike
    Applying the character should set the UVs - please report this as a bug in the product, assuming you are using the current version.
