Where would i find the UV map for a figure?
SertorialSertorial Posts: 962
I want to make some changes in Photoshop to a diffuse texture, but I need to be able to see exactly where a part of the texture ends up on the figure. So I'd like to be able to make a layer and paste the UV map on to it to guide me.
Problem is, where would I find the UV map (in an image format that I can paste into Phosotshop)?
    Many figures come with a template which you can load up. The majority of content on the store includes links to the templates on the product page. Failing that you'd have to load it into a modeller and 'extract' the UV map using what tools are available. You can view the UV's using Daz Studio as well and take a snapshot using the Clipping Tool. The downside to this approach is that the result will be fairly low resolution and may not be suitable for your needs.
  • SertorialSertorial Posts: 962
    edited February 2014
    Can you suggest a "modeller" I could try?
    what's the clipping tool?
    Post edited by Sertorial on
    There is a free version of UV Mapper which will let you print out the template
    http://www.uvmapper.com/
    cool! thanks
    um... it exports the UV as something called UVS files... what's that? I need JPg or somesuch for photoshop
  • SzarkSzark Posts: 10,634
    Humm so don't we get Templates for Gen and Gen 2 etc etc...we did for the Generation 4 figures?
    I am pretty sure uvmapper can save as jpgs, I don't have it installed yet so I can check.
    cool! thanks
    It is a little strange, but to get a 'template' type file, just use the Save Texture Map (ctrl-t) option. You'll be able to save it as a bmp image file.
    cool! thanks
    Thanks
